Sony LCD TV Model KDL-32XBR4 with Colored Vertical Lines Across Screen
Discussion in 'Electronic Repair' started by [email protected], Aug 15, 2010.
  1. Guest
    I am a TV service technician working on a Sony LCD TV
    model KDL-32XBR4 with colored vertical lines across the screen.
    I have worked on many CRT TVs, but not many LCD TVs yet.
    I don't have the SM for this TV. A web search was not
    very productive on the cause of this problem.
    Has anyone repaired a problem like this?
    Thank You in Advance, John
    PS, Remove "ine" from my email address
  2. Franc Zabkar
    Franc Zabkar Guest
    According to Google, your set has a WAX3 chassis.
    Here are several Google hits for service manuals for sets
    incorporating the WAX3 chassis:
    http://www.go-gddq.com/upload/2009_05/09051910005570.pdf
    http://www.go-gddq.com/upload/2009_08/09081412145687.pdf
    http://www.go-gddq.com/upload/2009_08/09081413392117.pdf
    - Franc Zabkar
  3. Guest
    Two possible causes
    T-con (usually behind a shield at the top of the LCD panel. The
    cable from the main board connects to it.
    Bad LCD panel.
    The service manual is available at www.elektrotanya.com
    PlainBill
