Sony KV-35V36 Dead?
Discussion in 'Electronic Repair' started by Bill, Oct 13, 2003.
  1. Bill
    Bill Guest
    I have a Sony Kv-35v36 that while watching it it changed inputs from
    Cable to Video by itself. Used remote to change input back to cable was fine
    for a while then went dead. No relay noice or High voltage sound when I try
    to turn it on with remote or switch. How were the solder joints on this
    Model? I have read certain Models have had problem.
    Thanks !
    Bill
  2. David
    David Guest
    From the description of the symptom before it went dead, it really sounds
    like someone sprayed glass cleaner on the front of the tube and it dripped
    down into the buttons. Once a button is shorted, the tv will not turn on.
    As to solder connection problems, the horizontal output and driver need
    checked. If the HOT shorted you can be guaranteed the SMPS needs repaired.
    David
  3. Bill
    Bill Guest
    Good point but the buttons on this set are on the top. She usually just dust
    it off. I will check your other suggestions latter this week.
    Thanks!
    Bill
