W
William Buchholz
When I power it up the screen is bright blue with retrace lines. The
picture is barely visible except for some faint outlines. The
voltages on the CRT are the following:
Blue Cathode: 139V
Green Cathode: 206V
Red Cathode: 206V
G1: connected to ground on socket
G2: around 500V but the voltmeter is probably loading this down
Heater: 6V
I tried using my B&K 445 tube tester to see if the tube it shorted. It
tests OK but I don't know if it works properly on Trinitron tubes. I
used an isolated heater supply but it made no difference in the
picture. Switching the red and blue cathodes resulted in a slightly
purple picture but still mostly blue. I would like to know how to
confirm if the blue gun is really shorted out. Thanks.
Blue Cathode: 139V
Green Cathode: 206V
Red Cathode: 206V
Heater: 6V
