Sony KV-27V10
Discussion in 'Electronic Repair' started by George, Nov 6, 2003.
  1. George
    George Guest
    It developed a problem where the video input label never goes off. Example,
    if I switch fron video 1 to video 2 the video 2 label on the upper right
    always displays except when another command which uses OSD is issued. So if
    I adjust the volume the video input label goes away when the volume OSD is
    active. I tried unplugging it for 12 hours with no result. Any suggestions?
  2. Sofie
    Sofie Guest
    suggestions?
  3. George
    George Guest
    That was it. I dug up the factory remote and it worked. As a point of
    interest why would someone want to toggle the video input label on?
  4. Jerry G.
    Jerry G. Guest
    The label is to allow someone to know what mode the set is in without
    interrupting the program being watched to find out. Leaving the label on all
    the time, may result in screen burn. I have seen these labels burned in to
    the screen.
    Greetings,
    Jerry Greenberg GLG Technologies GLG
    WebPage http://www.zoom-one.com
    Electronics http://www.zoom-one.com/electron.htm
