Sony KP-53V35 Will not power up
Discussion in 'Electronic Repair' started by Mud_komander, Sep 20, 2006.
  1. Mud_komander
    Mud_komander Guest
    I was given a Sony KP53V35 in hopes to fix it and give it to this lower
    income family in our church. The problem is Im trying to diagnose the
    exact problem and try o see if it does need a part is the part still
    available and is it worth getting it to repair. The problem is when the
    tv is plugged in and you push the power button it sounds like it is
    about to come on but then the timer/standby button blinks red and then
    shuts back down. I think it sounds like a power supply problem but I
    could use some second and/or third opinions. The tv was manufactured in
    September 1996. Exactly ten years ago. So I dont know if parts are even
    available. Thank you for any help.
  2. b
    b Guest
    Mud_komander ha escrito:
    not familiar with this model but it sounds like the set is in
    protection mode due to a short or other problem on the power supply
    secondary side.
    Judging by your post I take it you have little experience in Tv
    repair. If so, I strongly suggest you do not go poking around in it,
    risking your life. Take it to a tech for a good diagnosis and estimate.
    regards, -B.
  3. Guest
    Guest Guest
    SYMPTOMS
    Unit would go into immediate shutdown.
    RESOLUTION
    The problem caused by IC202/A board loading down the 12v line. Replacement
    solved problem.
    From http://fletchersite.com
