Sony hcd-sa30 very hot
Discussion in 'Troubleshooting and Repair' started by JENKI, Jun 5, 2013.
  1. JENKI
    JENKI
    3
    Jun 5, 2013
    Hello
    I have sony hcd-sa30 home theatre and amplifire are very hot and on speaker stop working after five minutes.
    All voltage is OK.
    What are could be wrong.
    Thanks for help
    Janez
  2. Ian
    Ian Administrator
    1,487
    435
    Aug 23, 2006
    Sometimes that can happen if the amp overheats (for protection).
    Have you got the amp in a confined space and is ventilation adequate? Check that airflow is ok and that there's no dust clogging vent ports. Does the amp remain powered/cool if you disconnect all the speakers?
  3. JENKI
    JENKI
    3
    Jun 5, 2013
    If i have disconnect the speakers, is the same overheating.
    Only if I disconnect the the connector on plate dmb 03 witch they are connecting to amplifire, then is not overheating.
  4. shrtrnd
    shrtrnd
    3,821
    519
    Jan 15, 2010
    Are the speakers the correct ones for your amplifier?
    Ian's explanation sure sounds like the problem to me.
  5. JENKI
    JENKI
    3
    Jun 5, 2013
    Yes I have the original speakers
