Sony HCD-H5
Discussion in 'Troubleshooting and Repair' started by mundraguda, Feb 23, 2014.
  1. mundraguda
    mundraguda
    Feb 23, 2014
    I have an old Sony HCD-H5 deck, European model.
    It doesnt power on and after searching the web I found a post on this site (very old) that says it could be either or both:
    • bad 5v power regulator
    • leaked transistor
    I have the service manual.
    Appreciate any guidance in locating if the above 2 issues could be the problem. Starting with the power board, where do I look first?
  2. AlenZGB
    AlenZGB
    174
    5
    Feb 19, 2014
    Id start something like visual inspecting the board.
    Most of the problem i solved like that,sign of damaged,fried or loose connections.
    Im not an expert,just trying to help, maybe i inspire to for another idea :)
  3. mechtronics
    mechtronics
    153
    Aug 7, 2011
    open it up take a visual look at where the power socket goes into the pcb and have a look to see if there are burn marks around hat area. a few pics would be good to put up for us to take a look.
  4. shrtrnd
    shrtrnd
    3,772
    493
    Jan 15, 2010
    Don't forget checking the fuse.
  5. mundraguda
    mundraguda
    Feb 23, 2014
    800ma fuse blown
    Thanks!
    The 800ma fuse on the power board was blown. I'm getting a delay 800ma 250v (same rating) replacement. The other 1.6v fuse is fine.
    I'm hoping the transformer is ok, because there are no leaks or burns anywhere.
    Thanks again.
  6. mechtronics
    mechtronics
    153
    Aug 7, 2011
    the blown fuse would suggest the problem!! thank god for fuses eh?!!!!!
  7. davenn
    davenn Moderator
    13,669
    1,891
    well that may be all it is, tho fuses don't blow for no reason
    it may be indicating another fault
Similar Threads
Loading...
