P
Peter V Rawlings
I've had this 19" FD Trinitron-based unit for around 5 years. Quite early
on, the black became greyer and flyback-like white diagonal lines started to
become visible. In truth, the situation has 'flattened out' now, but I'm
sure this is a burn-in issue that once adjusted back is likely to go the
distance - yes?
I realise this is not uncommon for the E400 - where the on-screen set-up
does not allow you to turn the brightness down any further - clearly there
is early life drift in one or more of the HT/EHT components. :-(
Is there a simple one-touch adjust inside that is going to let me bring down
the black level without losing geometry or have other set-up interactions?
If it is straightforward, an ident/location of the trimmer would be greatly
appreciated.
Cheers,
Pete.
distance - yes?
appreciated.
Cheers,
Pete.
