sony digital optical output dropout
Discussion in 'Hobby Electronics' started by bristan, Sep 9, 2011.
  1. bristan
    bristan Guest
    I recently purchased a Sony av receiver to go with my 3 year old Bravia Tv.
    On connecting the optical digital output from the tv to the amplifier, an
    intermittent dropout of the sound became apparent.
    The dropout is about a second long and can be spaced anywhere from part of a
    second to 90 seconds or so. When I disconnected the Sony TV and connected
    the Amp to a late model Samsung TV , the sound was ok.
    Any ideas as to what is wrong with the Sony TV? Do the output connections
    need cleaning at all?. The TV is quite awkward to get off the wall as it is
    very heavy etc and I can't get to anything without taking it off the wall. I
    am using the RCA connections instead at the moment as the hdmi to the tv
    doesn't appear to have audio return channel.
  2. shrtrnd
    shrtrnd
    3,685
    457
    Jan 15, 2010
    Is the Sony hard-wired or infrared or wireless?
    Anything interferring with the signal from where the new and old TV's are located?
    If this is a new Sony, they should have a technical assistance phone number or email
    contact. I'd try that. They'll ask you what you have hooked-up, and suggest solutions.
  3. bristan
    bristan Guest
    "kreed" wrote in message
    Might be dirt, dust, insect in the hole, if you have had it for 3
    years and never used the socket, and it has not been covered.
    I'm hoping that's all it is. I shall put the vacuum cleaner over the hole.
  4. Barry
    Barry Guest
    Good thinking.
