K
[email protected]
Long time listener...first time caller ;-)
I have a limited knowledge of Camcorders. That being said, I do
understand how 8mm backup tape drives work. I'm sure the two are
similar in operation.
The issue that I'm having with this unit, is that the tape does not
play at a constant/proper speed. In a cyclic fashion (approx 1 cycle
per second), the tape speed slows then returns to normal playback
speed. This is too slow to be playback head related.
My first thought, knowing the problems with electrolytic caps with
these units, was the possibility of bad capacitors in the capstan
motor circuitry.
Any thoughts?
I'm also looking for a repair manual for this camera (I have two, the
other one doesn't eject...but it's a parts unit).
Thanks in advance,
_kevin
motor circuitry.
Any thoughts?
Thanks in advance,
_kevin
