Sony 36" TV dead.
Discussion in 'Electronic Repair' started by Dani, Feb 15, 2007.
  1. Dani
    Dani Guest
    Model # KV36-FV15, high voltage comes up, at turn on, but drops away
    right away. Horizontal
    output, drive, & switching transistors chech fine in the power supply,
    suspect flyback. Can't locate one, seems NLA. Any other common faults
    with this set? Thanks, Dani.
  2. Jim Land
    Jim Land Guest
    The flyback is apparently in stock at www.tritronicsinc.com and
    www.partstore.com.
  3. Dani
    Dani Guest
    Update: Unplugging the CRT socket, lets the T.V. stay on, but no
    sound, or input change can be noticed. Also, unplugging
    the high voltage 2ND anode to the CRT gives filiament, but no yoke
    buzz. I'm thinking there is high voltage with no, or very little
    horizontal drive. It's
    an odd problem. Dani.
