Something weird happened with a resistor and a mosfet
Discussion in 'General Electronics Discussion' started by Paligap, Apr 5, 2016.
  1. Paligap
    Paligap
    27
    Feb 23, 2016
    Today I was playing with the PSU of some broken WII, I opened it up and took out a 101 smd resistor that was between a zener diode and some mosfet on the first instance of this PSU. Then when I was trying to put it back, one of the pads of the resistor made contact with one of the pins of the mosfet and bam! A huge spark ocurred, which scared the hell out me.
    The resistor is fine but the pin of the mosfet looks bad, lol.
    I don't know what happened.
  2. cjdelphi
    cjdelphi
    1,096
    104
    Oct 26, 2011
    A shorted/blown mosfet, pictures ?
    (Measure the resistance between all the pins or set to continuity and test)
  3. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    I sure hope that was a capacitor and that you didn't leave it plugged in...
    Capacitors (especially in power supplies) can store a lot of energy for a long time.
    Working on them can be dangerous if you don't consider the capacitors.
  4. Paligap
    Paligap
    27
    Feb 23, 2016
    It wasn't the capacitor, it was the mosfet, I shorted the capacitor right after I opened the PSU, I've been shocked by capacitors in the past so Im always very careful about it.
    And I actually saw the these two compnents making contact with each other and saw the spark coming from there. It's just a curious thing to me that I wanted to share.
  5. HellasTechn
    HellasTechn
    1,544
    215
    Apr 14, 2013
    Was the psu pluged in ? If yes then that could have proven fatal !
    Never Ever work on energized circuits ! If it is imparative to do so then you must exercise extreme caution.
