something is wrong with these capacitor in Socket 370 motherboar...
Discussion in 'Electronic Repair' started by wefixpcmotherboard, Mar 15, 2006.
  1. something is wrong with these capacitor in Socket 370 motherboar...while
    using a multimeter:
    top of two caps measure around +5.0 V
    and one cap is measured at -9.0 V.
    top of the cap with the red lead and the black lead is with common.
    why?
  2. Smitty Two
    Smitty Two Guest
    I hope English is your second language. And I hope you're continuing to
    study it concurrently with your electronics studies.
    I try not to criticize people for their grammar, spelling, and sentence
    structure, but you're going to have to try to make this query resemble
    something that could be deciphered if you want a useful answer.
  3. Adrian C
    Adrian C Guest
    Hmmm... where does the negative connection to this cap go? If ground and
    same manufacturer model/series as the other caps, then this part is
    either reverse biased (and probably been inserted backwards), or you are
    measuring an AC signal weighted with a strong negative component enough
    to fool your meter!
    Model/Name of motherboard, detected fault and general area of the cap's
    location is useful to mention.
  4. the top of a cap is always metal. the normal rating is around 0.5V. When I
    powered up the motherboard, only three of these caps have very strange
    measurement.
    all other caps have normal rating.
  5. Adrian C
    Adrian C Guest
    You KNOW you can get motherboards serviced by the manufacturer, or if
    cheap enough toss 'em.
