Someone please help clicking relay
Discussion in 'Troubleshooting and Repair' started by the bean, Apr 24, 2016.
  1. the bean
    the bean
    12
    Apr 23, 2016
    have a Panasonic message chair a relay on the circuit board continuously clicks. Chair not working. Where to start what may be causing the relay to click
  2. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    Start by letting us know the model number.
    What makes a relay click?
    First thing is to identify it and the function it performs in the circuit.
  3. (*steve*)
    25,497
    2,839
    Maybe the message chair is sending its messages as Morse code?
  4. the bean
    the bean
    12
    Apr 23, 2016
    The model # EP1015
    How do I tell what function it performs. I know not so much about circuit boards almost believe morse code haha
  5. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    LOL,
    Or he thinks it's is 2nd life as a metronome.
  6. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    We need to find the service manual or the schematics.
    You should tell us the part number identifier of the relay on the board.
  7. the bean
    the bean
    12
    Apr 23, 2016
    It's one of three relays it's very hard for me to tell any ideas I found a service manual on the web I will try and post the link soon
  8. the bean
    the bean
    12
    Apr 23, 2016
  9. 73's de Edd
    73's de Edd
    3,121
    1,315
    Aug 21, 2015
    Sir . . . . . . . . bean
    Looks like there is absolute minimal info on any control board info that they are wanting you to know in that literature..
    But, in looking at the mechanical aspects of its manner of construction, there are absolutely
    multi mechanical aspects, able to make noises akin to that of a relay.
    If you have tracked it down to a relay, a fingertip sequentially resting atop of each will tell you a lot,
    as being compared to ones depending upon aural source differentiation.
    73's de Edd
  10. cjdelphi
    cjdelphi
    1,096
    104
    Oct 26, 2011
    Clicking and failing to stay energized makes me think the power supply is failing
  11. the bean
    the bean
    12
    Apr 23, 2016
    image.jpeg image.jpeg image.jpeg Here are a few pics of the board. I wish I could tell which one. Is it possible all of them?
  12. the bean
    the bean
    12
    Apr 23, 2016
  13. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    No need to bet.
    Put your finger on the black plastic casing (without touching any thing else) ,
    you will feel the clicking one very clearly.
  14. cjdelphi
    cjdelphi
    1,096
    104
    Oct 26, 2011
    Before you removed it, i would simply place my finger on top of each relay until i felt the clicking
    Check fet502 and the other transistor (see if you get any shorts)
    Maybe, can't tell from the picture but there looks like a bridge rectifier next to the fet502 ? If so check that as well, when powered up you will see AC one side and DC the other, make sure that's working..
  15. the bean
    the bean
    12
    Apr 23, 2016
    Ok I did that it is ry503
  16. the bean
    the bean
    12
    Apr 23, 2016
    What color is the rectifier and please explain how to test it. And which one is fe502 and how to test
  17. the bean
    the bean
    12
    Apr 23, 2016
    Here are a few pics of the other side of the pcb. What does the D502 Q502 and R502 signify
  18. the bean
    the bean
    12
    Apr 23, 2016
    Sorry I don't know much about circuit boards and components but I am willing to learn. Still need help I appreciate all the help to this point
  19. Minder
    Minder
    3,102
    664
    Apr 24, 2015
    Presuming the relays are DC operated, I look first for the usual diode placed across the coil, it is usually adjacent to the relay, a meter across the diode when the relay is activated will sometimes tell if it is a low voltage problem, or the device operating the relay is turning on/off, relays click or chatter because one of these two reasons.
    They show as 5v DC type.
    A place to start.
    M.
  20. the bean
    the bean
    12
    Apr 23, 2016
    Minder here is a picture of the board in question can you please point out which one is a diode image.jpeg
