Somebody knows Karnaugh???
Discussion in 'Electronic Design' started by fender precision, Sep 9, 2004.
  1. Hi, I've learned many years ago how to transform from a thruth table to a
    logic simplified circuit. I try to remember how it works, don't remember.
    Can somebody help me please?
    Thank you
    If you can, answer me directly in my e-mail
  2. Jim Thompson
    Jim Thompson Guest
    I'm not quite sure where I learned Karnaugh maps.
    It's not something easily taught via the newsgroup.
    But there are MANY good books, for example....
    "Switching Circuits for Engineers" (second edition)
    Mitchell P. Marcus
    Prentice-Hall 1967
    Chapter 7 covers "maps".
    ...Jim Thompson
  3. John Larkin
    John Larkin Guest
    Google "Karnaugh map", first hit.
    John
  4. maxfoo
    maxfoo Guest
    freeware k-map software
    http://www.puz.com/sw/karnaugh/kmap12.exe
  5. Tim Wescott
    Tim Wescott Guest
    Hmm. "Karnaugh map" gives me 11400 results on AltaVista. Surely some
    of them are about logic minimization, not how to get to the wedding of
    Karen Klibschein and Kevin Karnaugh.
  6. Do they give the shortest possible route?
  7. Travis Hayes
    Travis Hayes Guest
    Jack Crenshaw has been doing a series on logic reduction for these past two
    months in Embedded Systems Programming. Last month was Karnaugh maps, this
    month is Quine-McClusky. Check out their website at www.embedded.com.
  8. Tim Wescott
    Tim Wescott Guest
    One hopes it would stick to the roads, rather than giving the _shortest_
    possible rout.
  9. keith
    keith Guest
    You haven't done state machine design? The shortest path between two
    points is via the great-bubble.
  10. J M Noeding
    J M Noeding Guest
    suppose Karnaugh diagram was something we used when everything should
    be done with SN7400N or was it something RTL ?
    jm
  11. Jim Thompson
    Jim Thompson Guest
    I remember RTL (and DTL) very well ;-)
    ...Jim Thompson
  12. keith
    keith Guest
    RTL is Register Transfer Language. What's DTL daddy? ;-))
  13. Jim Thompson
    Jim Thompson Guest
    RTL = resistor-transistor logic, circa 1962
    DTL = diode-transistor logic, mid to late '60s
    ...Jim Thompson
  14. J M Noeding
    J M Noeding Guest
    remember buying some US surplus electronic tube equipment around 1960,
    wonder what sort of logic was used there?
    -jm
  15. I read in sci.electronics.design that J M Noeding <>
    TRL - triode-resistor logic
  16. Ken Smith
    Ken Smith Guest
    How about RRL (relay relay logic)
    Where I work we used to make a product using a fair amount (5) or RRL to
    implement all the safety interlocks etc.
    There was also a fair amount of MML[*] in another product.
    [*] MML Mickey Mouse Logic: The fine art of combining RLC circuits with
    logic gates to implement logic circuits.
  17. Fred Bloggs
    Fred Bloggs Guest
    Right- well the "thruth" table method is different from Karnaugh maps
    which are useable only to five variables. The "thruth" table is first
    used to write a either a standard sum of products or standard product of
    sums in terms of the input variables. Then twelve simple rules of
    Boolean algebra are used for the minimization:
    1. A+0=A
    2. A+1=1
    3. A.0=0
    4. A.1=1
    5. A+A=A
    6. A+A'=1
    7. A.A=A
    8. A.A'=0
    9. (A')'=A
    10. A+AB=A
    11. A+A'B=A+B
    12. (A+B).(A+C)=A+B.C
  18. Fred Bloggs
    Fred Bloggs Guest
    What about the short-lived era of discrete solid-state component logic
    with trigger coupling capacitors, steering diodes, collector clamps for
    rise time speed-up, and innumerable other circuit cleverness. The legacy
    of this era for complex systems was adoption of the SEM or Standard
    Electronic Module approach to design and this was carried into the RTL,
    DTL, and even early TTL era. This has nothing to do with "thruth" tables
    however.
  19. Fred Bloggs wrote...
    I remember using those, starting with modest-sized PCBs, but graduating
    to small square modules, with a footprint not too much larger than DIP
    packages, and made by companies like Cambion, IIRC.
    In the days of $10 modules, motivation for logic minimization was high.
  20. Jim Thompson
    Jim Thompson Guest
    See "ToggleFlopAncient.pdf" on the SED/Schematics page of my website.
    ...Jim Thompson
