I have the following setup below for my project Container Overheat Indicator .
Materials:
1pc TC4-M1A temperature controller
1pc 12v 3PDT Relay
1pc 12v LED Warning Light
Algorithm:
1. The Temperature Controller will read and display the temp. of the environment
2. If the temp reading reaches 70 deg C, the temp controller will turn on the 3PDT relay through its own Relay Output
3. The 3PDT relay will turn on the 12v LED Warning Light as long as the temp reading is 70 deg C or above
4. The 3PDT (and the Light), will be turned off by the Temp Controller if the temp reading is already below 70 deg C.
Questions:
1. The datasheet does not indicate that the Relay Output of the Temp Controller may be used for DC loads ...
It only says:
"Relay Output: 3A/250V AC Capacity"
However:
I still tried connecting the 12v 3PDT Relay to the Temp Controller's Relay Output.
And everything works fine, and the algorithm was followed seamlessly .
Is it ok to continue doing that ? Is there going to be any problem if I continued doing that?
2. Do I need to use a flyback diode for the 3PDT relay?
I uploaded below my setup diagram and the Temp Controller's images and sheets .
Thanks !
Materials:
1pc 12v 3PDT Relay
Algorithm:
Questions:
It only says:
However:
Thanks !
