some questions about high precesion constant current source
Discussion in 'Electronic Basics' started by [email protected], Aug 29, 2005.
  1. Guest
    hi,everybody.
    I have some questions about hight precesion constant current source.My
    goal is 1uA whose error is blow 0.01%.
    In my circuit I used a op-amp,p-mosfet and 5V voltage reference.
    But the result is so bad,the error is almost 1%.
    Could somebody give me some hints?
    Thanks very much.
    eehinjor
  2. eehinjor
    eehinjor Guest
    added:
    1,the voltage of the load is between 0V~5.5V.
    2,the output of voltage reference is 5V.
    3,the sources of op-amp are +12V and -12V.
    thanks
  3. So you must have a current sense resistor that drops 5 volts when 1 uA
    passes through it. That would be a 200k resistor, right? In order
    for the closed loop to have .01% accuracy, not only do you need
    sufficient loop gain, but the opamp input impedance would have to be
    more than 10,000 times this 200k, or greater than 2 giga ohms. What
    opamp are you using?
  4. Chris
    Chris Guest
    Hi, eehinjor. Welcome to the newsgroup. For things like this,
    typically
    * 1% is easy -- just cobble together a cookbook circuit
    * 0.1% requires quite a bit of attention to detail, but is usually not
    too tough and somewhat more expensive
    * 0.01% starts getting into lab quality -- really tough and much higher
    cost for precision components
    or M$ Notepad):
    ` VCC VCC
    ` | | '----------o
    ` R1| | 1uA
    ` '-' .----------o
    ` |5.000V VCC | <---- -
    ` o-----. + |
    ` | | IC2 | |
    ` IC1/-/ | |\| ||-+
    ` ^ '-------|+\ ||-> Q1
    ` GND | GND |
    ` '------------o
    ` R2 | |
    ` GND
    created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
    (You might want to download Andy's ASCII Circuit -- it's a lot easier
    to use a picture to describe what you're doing.)
    If you would, a few questions:
    * If the above circuit is correct, could you please specify what you're
    using for IC1, IC2, R2 (wirewound/metal film/metal oxide/carbon film,
    with tolerance), and Q1? Each one of these components could easily be
    the culprit. If the above isn't correct, what's different?
    * What's your budget? If you actually had to pay much more than a
    couple of bucks for 0.01%, would you still want it as badly? Can you
    live with less?
    * Do you need accuracy as well as precision? In other words, do you
    need an 0.01% DC current source at somewhere around 1uA, or does it
    have to be exactly 1.00000uA? That's going to be more difficult.
    * What's the temperature range for this circuit?
    * You've said you've got a burden which will cause a load voltage
    between 0 and 5.5V. But you didn't describe the load, or what you're
    doing with it. Is this an instrument which has banana jacks, and you
    want 200 feet of wire going out to the load and back? Is the load
    purely resistive? Are you planning on unplugging it while the circuit
    is on? Or only off? Please describe.
    * Have you put a scope on the output, looking for oscillations? This
    is basically a unity gain non-inverting amplifier, and is prone to
    misbehaving. Depending on your components, your circuit may actually
    be operating correctly as a high speed oscillator.
    * While we're on the subject, what are you using to measure current and
    check your circuit? Even measuring DC current to that accuracy
    requires a bit more than a handheld DVM.
    If this is a dedicated circuit with a purely resistive load in very
    close proximity to your circuit, it might be easier to lose the FET and
    do something like this:
    ` .---. R(load)
    ` | | + ___ -
    ` === | .-o--|___|--o---.
    ` GND | | |
    ` /-/ | VCC |
    ` | ___ ___ | |\| |
    ` -5.000Vo--|___|-o-|___|---o---|-\ |
    ` '-' '-' === Vee
    ` | | GND
    ` Vee GND
    By using a pA input low drift op amp and high precision low temperature
    coefficient resistors, you might be able to get close to 0.01%
    precision without too much difficulty within a lab temperature range if
    your reference is up to the task. Getting it accurate to 1.00000uA,
    though, would pretty much be luck, or would require careful nulling of
    the op amp offset and an adjustable reference, which has its own set of
    problems (like potentiometer drift with temperature, &c).
    Of course, this basic circuit won't help you if you've got those
    hundreds of feet of wire, a reactive load, or you have to be able to
    disconnect the load hot. It also is very susceptible to ESD damage, as
    you've got an op amp input floating in the breeze.
    A better response awaits more information from you.
    Good luck
    Chris
  5. Damn, I have to get some caffeine in me before posting. 5 volts
    reference with 1 uA current implys a 5 mega ohm current sense resistor
    and an opamp impedance of 5 gig ohms for .01% accuracy. Of course,
    the sense resistor also has to be accurate and stable to better than
    ..01% and so does the reference. The opamp offset voltage must also be
    less than a half millivolt. The frequency response of such a source
    will also be accurate only for very low frequencies where capacitive
    current is less than .01% of the source current.
  6. eehinjor
    eehinjor Guest
    Thank you very much.
    I know this is very difficult,I have done some experiment,but all the
    result is so bad.
    The resistor is 5000K.In my circuit,the op-amp is OPA602.
  7. John Fields
    John Fields Guest
    inverting
  8. The opamp is pretty good (bias current within minimum requirements and
    offset voltage probably also). But what is the gate leakage current
    of your PMOS transistor, and how do you build this thing with surface
    leakage current to the sense node much lower than the .1 nA error budget?
  9. eehinjor
    eehinjor Guest
    the type of my p-mosfet is VP0610L.its gate leakage current is only
    10nA(max.).
    Unfouturnately VP0610L is obselete from last year,I don't know which
    one can replace it or better than it.
    I used a intrument of Agilient,the type is 3458A.it can measure current
    as low as 1nA.
  10. Yikes. That is 100 times your leakage current budget of 0.1 nA.
    I don't know what a better one would be, but it must have lower gate
    leakage and probably would be a much smaller die, maybe rated for a
    higher voltage.
  11. eehinjor
    eehinjor Guest
    Thank you very much,John.
    But when I try to use this circuit to realize 1mA constant current
    source,the result is also unsatisfied.
    I don't know the reason,so I am afraid the circuit is wrong.
  12. I haven't seen your circuit, including the test setup that you are
    using to get this unsatisfactory result.
  13. mike
    mike Guest
    At what level of accuracy do you have to start worrying about
    thermoelectric effects of the interconnect?
    mike
    Return address is VALID but some sites block emails
    with links. Delete this sig when replying.
    Wanted, PCMCIA SCSI Card for HP m820 CDRW.
    FS 500MHz Tek DSOscilloscope TDS540 Make Offer
    Wanted 12" LCD for Compaq Armada 7770MT.
    MAKE THE OBVIOUS CHANGES TO THE LINK
    ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
  14. eehinjor
    eehinjor Guest
    Thanks all.The circuit is shown as below.
    Q1:VP0610L;
    Q2:2N4402;
    RL:the load(resistor);
    IC1:OPA602;
    R1:the resistor(5000K ohm),it is composed of 4990Kohm fixed
    resistor(0.1%,15ppm/c) and a 20Kohm variable resistor;
    +12V,-12V:power;
    +7V:it is produce by INA105 and AD586(+5V voltage reference);
    +5.5V:to avoid the voltage of RL over this value;
    In fact,my goal is 1mA/100uA/10uA/1uA when R1 is 5K/50K/500K/5000K.
    By the way,the VP0610L has been obseleted from last year,would you like
    recommand one?
    result is so bad.I don't know how to modify it.
    +12V
    R1| |
    |-----------------------o
    | +12V |
    | IC1 | |
    o-------------|-\ ||-> Q1
    +7V--------------|+/ |
    -12V |-------------------o
    +5.5V----| Q2 | |RL
    o------------------ o
    GND
  15. eehinjor
    eehinjor Guest
    Thank you,Chris.
    There is a little difference between our circuits,but the theory is the
    same.
    I don't know what IC1 is in your first circuit.
    Maybe I am confused between precesion and accurary.I only mean the
    result shoule be 0.9999uA~1.0001uA.
    The temperature is from 20C to 70C,of cource the wider the better.
    The load is resistor,when its value is 5500Kohm and the current is
    1uA,the voltage will be 5.5V.
    waiting for your response.
    best regards.
  16. That not only depends on the level of accuracy, but on the reference
    voltage. This design, supposedly is based on a 5 volt reference.
    That is pretty huge compared to thermoelectric effects.
  17. eehinjor
    eehinjor Guest
    Just now I simulate the Chris's first circuit,found the result is
    worse.
    especially when the load is smaller than 500K,the output is not
    constant.
  18. Chris
    Chris Guest
    Hi, eehinjor. Apparently you've cross posted your question over at
    sci.electronics.design as well as s.e.b. It's now clear that you are
    trying to make a DC current calibrator with switchable currents in
    decades down from 1mA to 1uA with 0.01% precision. Here's the key post
    from s.e.d.:
    A couple of points:
    * I believe the biggest hangup you're having with your P-MOSFET circuit
    is getting a 5 Meg resistor to stay stable to 0.01%. Higher resistance
    values are a bear. Changes in ambient humidity are particularly
    troublesome in making effective resistance values drift all over the
    place. I would also be concerned about leakage current in the FET, and
    possible oscillations.
    * The second circuit I mentioned is only useful if you can put a
    resistive load on the circuit board within a couple of inches of the op
    amp. The circuit takes advantage of the "virtual ground" at the input
    of the op amp. The divider of your voltage reference is set to inject
    1uA into the inverting input. The op amp will work to put 1uA through
    your load to balance the injected current, and keep the input at 0V.
    This doesn't work if the feedback loop goes 2 meters through test probe
    wires to your load or a meter, and then back. The inductance of the
    leads and any noise pickup on the wires guarantees oscillation. The
    simple op amp current null circuit I suggested is not useful for you.
    You're discovering the hard way why current source meters with the kind
    of accuracy you're specifying usually cost thousands of dollars new
    (Keithley in particular is a good source for this kind of instrument).
    They produce a dial-in, rock-stable current under varying loads. You
    should know, however, that even these instruments are not specified to
    the temperature range you specify -- they generally are only spec'ed
    over lab temperature range.
    If you need a calibrator, you can take hope in the thought that used
    instruments are available at a fraction of the price of new. You may
    be able to get something close to what you want (if you can lose the
    commercial temp range) for hundreds rather than thousands of dollars.
    An 0.01% dial-in or switchable current source is not a trivial project,
    and not suitable for newbies.
    If you still want to pursue this as a project, reread all the responses
    to your posts in both newsgroups, particularly those of Mr. Popelish,
    Ban, and Winfield Hill. They've given you a free helping of really
    good practical advice.
    Then go to instrument manufacturer websites, and take a look at what's
    out there commercially, what it can do, and what it costs. These
    instruments are generally a real bargain, and give you good value for
    your money. You will see, if nothing else, that what you're proposing
    isn't exactly a trivial newbie project. If somebody could slap
    together a little perfboard circuit that does what you propose, they
    wouldn't be spending thousands of dollars for one of these instruments.
    Also, get the operation/service manuals on one of the older Keithley
    current sources, and take the time to examine the circuits in detail.
    There's a real education in doing that, and may help you in getting the
    knowledge you need to approach your job. But you might want to shoot
    for 0.1% at best, especially considering your temp range.
    Good luck
    Chris
  19. eehinjor
    eehinjor Guest
    Thank you Chris.
    This is my first time to google's group.This question is postd at
    sci.electronics.design.
    During these two days,I have learn more.There are little description
    about MOSFET in our book,so my fault is some knowledge about it.
    On your advice,I will do more expeiment step by step until the goal.
    best regards.
  20. Bob Masta
    Bob Masta Guest
    One thought you might want to consider:
    I have seen super-accurate *voltage* calibrators
    that work via digital counters. The basic idea is
    that you use a counter with some logic to go high
    for the proportion of time you want to divide the
    master reference by. For example, to produce
    1.0 V from a 10.0 V master, you generate a pulse
    that is high for one count out of 10, then use that
    to switch the master. You have to filter the result
    to get DC. That's easier at higher clock rates, but
    higher clock rates have more time spent in switching
    which needs to be compensated. Other than that,
    the clock frequency is not critical since the whole
    trick relies upon duty cycle, which being digital is
    rock-solid.
    Application of the above to *current* sources is
    "left as an excercise for the student". Just giving
    you an alternative approach.
    Best regards,
    Bob Masta
    dqatechATdaqartaDOTcom
    D A Q A R T A
    Data AcQuisition And Real-Time Analysis
    www.daqarta.com
    Home of DaqGen, the FREEWARE signal generator
