Solve noise for Amplifier board.
Discussion in 'Electronic Design' started by Chauny, Apr 20, 2007.
  1. Chauny
    Chauny Guest
    Hello peaple,
    I make a amplifier circuit with TDA2030, the amplifier works but when
    i connect it to loudspeaker, turn on the power, i hear noise from
    loudspeaker without input. I can not solve this problem although i
    make layout with center ground.
    Could anybody help me solve this problem?
    Regards,
    Chauny.
  2. describe the power supply please
    martin
  3. Eeyore
    Eeyore Guest
    What kind of noise ?
    Graham
  4. mpm
    mpm Guest
    I agree. Sounds like a power supply issue.
    I would look there first.
    Can you describe the noise it is making?
    Static, high-whine, low-rumble, something else??
    Also, how loud is the noise, and what sound(s) are you trying to
    amplify?
    Speech? Music? Simple tones?, a combintation?
    And while you're at it, what kind of speaker?
    -mpm
  5. D from BC
    D from BC Guest
    When you press your ear against the speaker, try not to move your ear
    around..That will make a rubbing noise.. :p
    D from BC
