Solid State Relays
Discussion in 'Beginner Electronics' started by Bryan, Jun 25, 2003.
  1. Bryan
    Bryan Guest
    Hello All:
    I wish to construct some solid state relays to control some lighting and
    heating. I plan on using a MOC3041/2 Optoisolator which I have in my parts
    drawer.
    Can anybody recommend a very commonly available and cheap Triac to use. The
    requirements are that the triac should be able to supply 4-5 amps at 120
    volts.
    There is a zillion triacs out there and I am not sure of the correct ones to
    use. I guess I should also specify a isolated To220 case as well.
  2. Look at bta16
