S
Signumx
I'm currently using a photovoltaic solid state relay (Fairchild
HSR312L) to open or close the path of a square wave signal. It works
fine but at over a 1$ per unit it's rather hard on my circuit budget.
I tried to replicate the internal circuitry of the chip (see datasheet:
http://www.fairchildsemi.com/ds/HS/HSR312L.pdf) by using two MOSFETs
with their sources connected together but I can't seem to turn off the
switch (open the path). Anyhow, would anyone have a suggestion of a
low cost, low current consuming solution to replace the HSR312L?
Thanks!
Thanks!
