Solid State Harddisk
Discussion in 'Electronic Basics' started by padmow, Apr 4, 2005.
  1. padmow
    padmow Guest
    I would like to have opinion about Solid State Harddisk.
    It would be great if my notebook computer is using this.
    thank you
    Padmow
  2. Yes it would be great, I hope your notebook does use one.
  3. mike
    mike Guest
    I've got a 10MB solid state hard drive in a 2.5" IDE format.
    Make an offer.
    mike
    Return address is VALID but some sites block emails
    with links. Delete this sig when replying.
    Wanted, PCMCIA SCSI Card for HP m820 CDRW.
    FS 500MHz Tek DSOscilloscope TDS540 Make Offer
    Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
    Wanted 13" LCD for Mitac 6133 Samsung HT13X13-201
    MAKE THE OBVIOUS CHANGES TO THE LINK
    ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
  4. Guest
    You mean like a 1 gig USB flash drive?
    GG
  5. Lord Garth
    Lord Garth Guest
    I have two 16MB M-Disk ICs plugged into two ICOP PC-104 cards.
    They work very well on these essentially 386-40 computers. I've
    even put Win 3.11 on them with a ram disk but later returned to a
    DOS only environment.
    What I want to know is if any of you guys ever connected a CF card
    to the IDE port and used DOS to format it into a proper HD structure?
    The result is easily loads more storage for the dollar than an M-Disk.
    Note the M-Disk is in a 600 mil DIP and plugs in as any JEDEC byte wide
    device would. The BIOS on the ICOP is set to boot this socket so
    having a CF on the IDE port means no special BIOS options are needed.
  6. No, my only experience was installing Embedded NT and the custom
    software in telemetry equipment using the 40 MB part on 586 (Cyrix)
    based PC104 boards.
  7. Lord Garth
    Lord Garth Guest
    Having worked at Cyrix, I shudder when their CPU is mentioned....
    The damn chip was huge and therefore costly, it ran an easy 30 degrees F
    hotter than Intel and their attitude toward known bugs was "**** them,
    let 'em buy a new chip." At the time, ECS was the only company that
    modified their boards to work with Cyrix. I wonder just why National
    bought them? I have a few Cyrix dice here in the museum.
    Though these guys were founder by Sevin Rosen Group, it wasn't one
    eighth the company that other Sevin Rosen ventures were.
