Solenoid... What power supply?
Discussion in 'Power Electronics' started by PandaMan, Oct 10, 2011.
  1. PandaMan
    PandaMan
    17
    Sep 13, 2011
    I want to use a solenoid to propel a small, very light block up a guide rod with enough force to ring a bell. I'm not sure of the exact weight of the block or the length of the guide rod, etc, but I thought a 9V or 12V battery would be best.
    I would, of course, be using a relay to keep the large voltage away from the PICaxe chip
    PandaMan
  2. shrtrnd
    shrtrnd
    3,773
    493
    Jan 15, 2010
    Your power supply, is going to depend on the parameters of whatever solenoid you select.
  3. PandaMan
    PandaMan
    17
    Sep 13, 2011
    *facepalm*.... thanks. I had a special moment :p
