solenoid power boost
Discussion in 'General Electronics Discussion' started by vaporlock, May 9, 2012.
  1. vaporlock
    vaporlock
    May 9, 2012
    Hi I am looking for a way to boost the power of a pull type solinoid 12 volts , 12.8 ohms. it is a choke sol. and does not have enough pull it is used for about 30 to 60 seconds once it pulls in it holds no problem but at first sometimes you have to help it so I just need a little boost any help would be apreciated
    thanks Ken
  2. BobK
    7,682
    1,688
    Wind more turns or up the current.
    bob
  3. timothy48342
    timothy48342
    218
    Nov 28, 2011
    @vaporlock
    vaporlock, welcome to the forum.
    Can you provide more information about the solenoid? A link to the datasheet or to the product description?
    Also more about the power source. Is it batteries? What is it?
    I'm an electronics novice, so the following suggestion is directed...
    @everyone else
    What about a large capacitor in parallel with the power source. (Large= a few hundred microfarads or maybe 1000uF. Like a photoflash cap.) My thinking is that it would sit at 12V and when the solenoid turns on it would provide a near zero source resistance for a brief moment to get things moving. If the power supply voltage drops a bit, the cap won't. Then once the solenoid engages, the cap would just come back to 12V until next time.
    Do you guys think that something like that might "up the current?"
    --tim
  4. Rleo6965
    Rleo6965
    585
    9
    Jan 22, 2012
    Try lubricate moving part of solenoid.
  5. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    I made a note of a circuit to speed up a relay some time ago. The circuit doubles the voltage on the relay by adding the capacitor voltage. It takes longer than normal to drop out as the capacitor has to recharge. You will need to size your components appropriately to drive the solenoid.
    K1KP ? In Practice RadComm April 2002 p55
