B
BretCahill
Could a solenoid be constructed to mimic
the proper valve position vs time curve of a
engine cam shaft? Maybe a circuit and/or
several coils in each solenoid?
It may be tricky or impossible to build such
a solenoid that works well over all rpms, but
if it could be built, it could be mass
produced very cheaply, maybe cheaper than
a cam system.
The other concerns such as force necessary to
accelerate valves (are solenoids orders of
magnitude more inefficient than cams?) and
mangled valves from electronic failure (like other
fail safe systems set the default of every valve
in a safe position) shouldn't be problems.
Bret Cahill
a cam system.
Bret Cahill
