is tat possible to solder jumper wire with bare wires?
V vamsee Jan 10, 2013 36 Joined Jan 10, 2013 Messages 36 Jan 24, 2013 #1 is tat possible to solder jumper wire with bare wires?
(*steve*) ¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd Moderator Jan 21, 2010 25,510 Joined Jan 21, 2010 Messages 25,510 Jan 24, 2013 #2 What are you doing?
V vamsee Jan 10, 2013 36 Joined Jan 10, 2013 Messages 36 Jan 24, 2013 #3 I want to solder 3 pin hall sensor to the bare wires... so tat i can calibrate at long distance (3mtrs)
Harald Kapp Moderator Moderator Nov 17, 2011 13,744 Joined Nov 17, 2011 Messages 13,744 Jan 24, 2013 #4 Where's the catch?
O oyvdahl Oct 11, 2012 15 Joined Oct 11, 2012 Messages 15 Jan 24, 2013 #5 Yes you can solder wires to jumpers. But if that has any implications for you is impossible to know without you explaining a bit more.
(*steve*) ¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd Moderator Jan 21, 2010 25,510 Joined Jan 21, 2010 Messages 25,510 Jan 25, 2013 #6 Well, the obvious answer is that the place where you want to solder, the insulation must be removed. But it would be very wise to use insulated wires (especially over a 3 metre cable run) to ensure they're kept apart and don't short out.
