Soldering rod problem part 2
Discussion in 'General Electronics Discussion' started by electronoobz, Aug 18, 2012.
  1. electronoobz
    electronoobz
    226
    Jan 14, 2012
    i did what the internet says, damp a sponge to clean the tip.
    now i cant touch the tip or solder anything. Idk what happened coz whenver i touch it im getting grounded always..
  2. (*steve*)
    25,500
    2,840
    I understand the first sentence, the second not at all.
    Can't touch the tip? (well, it's probably really hot). Getting grounded?
  3. electronoobz
    electronoobz
    226
    Jan 14, 2012
    no what i mean is before i can touch it to check if it's hot but now it's like there is a electricity coming out of the tip
  4. (*steve*)
    25,500
    2,840
    How is it "like there is electricity coming out of the tip"
    Do you measure a voltage with respect to earth?
    Do you see sparks?
    How did you use a damp sponge? The idea is that you wipe the tip (the part you solder with) on the sponge while the iron is hot. You should hear a bit of a sizzle and the tip should look bright and shiny again.
  5. donkey
    donkey
    1,300
    56
    Feb 26, 2011
    the only reason I can think that your iron is now electrifying you is that its damaged, it should not be zapping you. it is a closed circuit that produces heat, either a lose connection or a broken heating element will be the cause of you getting zapped
