Soldering question
Discussion in 'Electronic Basics' started by Chris W, Mar 25, 2005.
  1. Chris W
    Chris W Guest
  2. That looks easy enough to solder. It is a surface-mount
    assembly with the terminals flush against the outside
    boundary of the outline. If your pads extend a little
    beyond where the terminals are supposed to center,
    (which they should for inspectability anyway), then
    just put down solder paste, plop the assembly into
    place, and touch the iron or point the hot air to the
    accessible edge of the pad.
    I had about the same arrangement (except for the
    stood-off height) on a little RF transformer I had
    specified for a hybrid. Hand soldering them was
    essentially the same problem you anticipate. It
    was not at all difficult.
