Soldering newbie
"Tom Del Rosso"
This vid ( I posted earlier) shows how to use a pointy tip to solder
regular components like 1 amp diodes to a PCB with plated through holes.
The side of the tip is used and solder is constantly re-applied to the tip.
.... Phil
I call that work barely adequate and certainly wouldn't consider paying forit. Several of the joints don't have solder through the hole. That cutter belong in the recycling bin. I haven't done work that shoddy since I was ingrade school.
P
Phil Allison
<[email protected]
Phil Allison wrote:
"Tom Del Rosso"
tip.
for it.
** Luckily no one gives a flying **** what jerk offs like you think.
** Not very important.
The basic technique is what needed to be shown and that is OK.
BTW arsehole,
FIX your fucking news reader so it STOPS doubling the line spacing in quoted
material.
..... Phil
N
notbob
Yes, you can do it that way, or use the proper width chisel tip to
apply even heat and solder the joint properly by applying the solder to
the joint instead of the tip. We didn't have anything other than chisel
tips in the 100+ temperature controlled Ungar 'Loner' irons at
Microdyne. Even the .015" tips had a flat face so you could heat the IC
leg & pad instead of the solder.
Yep. At the very least, one should get an iron/station that has the
option of changing tips. I can still buy diff temp and tip profiles
for my ancient non heat-adj Weller.
nb
F
Fred Abse
Sorry, Phil, I have to disagree. Every quality control manual I know of,
NASA, MIL, etc, in the case of plated through holes, insist on complete
hole filling, plus a fillet each side.
Many PCB designs (mine included) don't have enough pad area to be
satisfactory without solder penetration. Pads large enough to be
viable on their own, waste real estate.
F
Fred Abse
We had special strippers that looked like long-nosed pliers
with a nick in the jaw (not the blade).
I still have a pair.
M
Michael Black
I can no longer remember who made what.
My first soldering irons for some reason lasted a very shrot time. I
wasn't abusing them, but they were cheap and overheated and soon died. I
was too inexperienced to figure out why. The first was new, a birthday
present, the second was used, someone gave it to me with a new cord
attached.
Somewhere about then I was given a Weller soldering gun, useful because
tubes were still being used. That gun has lasted me all these decades, it
was used when I got it, a few scrapes and burn points in the cord. The
cord has a lot of electrical tape on it now, and some years back I put
some epoxy on some places where there were cracks (though no structural
breaks). Finally a couple of years ago it fell off the bench, and the
lower part of the handle actually broke off. I drilled some small holes,
used some wire to "sew" it back together, then covered with epoxy, still
working fine though rather ugly looking.
So I decided to buy a new one, but they cost a lot now. I wait, and find
one at a garage sale for ten dollars, in a case with some accessories,
though a somewhat later model. Then last year I found one identical to
mine, but in much better shape, in the original box, for five dollars.
But after those first two soldering irons died prematurely, I went with
the system Radio Shack had at the time, a handle, a heating element and a
tip. I think Ungar made them, but they were branded Radio Shack. That
was great, except I kept dropping the iron, and the tip would break off.
The ones I liked (there was a variety) threaded into the heat element, and
thus without the means of drilling out the rest of the tip, the heat
element was junk too. I slowly got better, dropping the iron less. That
lasted about 20 years, actually the handle is still fine. I replaced it
with a newer model, direct from Ungar, this time having a third prong in
the AC cord.
That ones still working. I actually made up a stand for it, complete with
a light dimmer to vary the heat, even though I've never found that feature
all that useful.
Then a few years ago, I found a Weller soldering station, the light blue
kind with the magnetic tip that kept things the same temperature. Only
five dollars (it was the same place I'd found a drill press vice a couple
of years before), too cheap to turn down. My first temperature controlled
soldering iron in all these decades. Oddly, the switch had gone bad, the
previous owner adding some wire to bypass it. I thought of various
schemes to replace the switch, it's square so I didn't think I had a
direct replacement, then thought of the AC power strips I'd found a box of
lying on the sidewalk one night. The switch form one was a fit, so I did
the transplant, and the Weller soldering station is like new.
It's kind of neat, but I like the Ungar, I'm used to it, I'm used to the
feel in my hand, so though I have both set up right next to each other,
it's the Ungar I turn on much of the time.
Michael
P
Phil Allison
"Fred Abse"
** Did you view the vid at all ?
Or just playing word games again.
Every quality control manual I know of, NASA, MIL, etc, in the case of
** So fucking what ?
Huge numbers of commercial PCBs have empty vias.
Snipping it out makes me think you did not bother.
The soldering and PCB in that vid are the topic here - nothing else.
.... Phil
Not all wire wrap was done with silver plated Kynar. Some was tin
plated, and the airflow through the equipment pulled dirty air over the
backplane.
Ours was all copper with Teflon insulation. The problem with Teflon
was cuts if you stretched the wire too tight when going around a pin
(bypassing it, not wrapping to it).
Some Chyron video equipment was made with cheap WW sockets. The
wiring was so tight that you couldn't do practical repairs. The only
thing I could do was press good machine pin sockets into the cheaper
sockets to eliminate intermittent. The sockets were packed so tight
that they touched any adjacent socket to cram a lot of chips into a
small space. Three hinged boards, in a small space. I'll bet the
factory wouldn't even try to repair it without cutting wire and
soldering.
That's not incompetent? I always use machined pins (Augat sockets and
boards).
Our techs insist on using pointy tips in the Metcals at work. The
first thing I do when I sit down at their stations is to change the
tips to chisel tips (unless I'm working on really fine pitch stuff).
Fortunately, the Metcals only take five seconds, or so, to come up to
temperature.
F
Fred Abse
Irrelevant.
I was commenting on a specific, unambiguous statement that you yourself
made here, in response to someone else's observation.
You don't know about tented vias either? They're _supposed_ to be empty.
... Phil
And the soldering is sub-standard as are the tools.
P
Phil Allison
"Fred Abse"
Phil said:
Irrelevant.
** Fraid it was very relevant.
** But SNIPPED out of context and hence misinterpreted by you.
Go **** yourself - arsehole.
P
Phil Allison
<[email protected]>
Phil Allison wrote:
<snip>
** Bad boy !!
Do NOT snip the context !!
** Then go changing it like that - fuckhead.
** No one gives a **** about YOUR absurd, pedantic opinions .
Go **** yourself - shit head.
Jamie
Phil said:
<[email protected]>
Phil Allison wrote:
<snip>
** Bad boy !!
Glad you can drop in now and then Phil..
Jamie
