Soldering a Broken TV
I started having trouble with my TV after it was moved in a U-Haul from
San Francisco to Seattle. I managed to locate a faulty solder joint on
the board. Applying pressure to the joint with a strip of wood fixes
the problem.
My problem is this: I am very experienced with electronics and
soldering, but I have little experience when it comes to high voltage.
I need to fix the solder joint but I have no hardware to properly
discharge any high voltage capacitors in the TV. I don't think this is
a problem as the faulty solder joint is attached to what appears to be
a FET. However, it could also be a triac, which could mean that it's
attached to a HV part of the circuit. I don't want to stick my head in
there to find out exactly what it is. Would you advise fixing the
solder joint without first discharging the TV?
Thanks in advance!
M
Michael Black
the problem.
Thanks in advance!
Huh?
You're "very experienced in electronics and soldering" yet you don't
know whether something is an FET or a triac?
Michael
H
Homer J Simpson
the problem.
Fix it that way. You don't have the skill set to do more.
C
Clyde Crashcup ..........................
the problem.
Thanks in advance!
Just lay some steel wool or tinsel around where you will be working and
it will short out any voltage.
You are living somebody else's dream. The whole world, laws
and way of life; not your dream.
Clyde Crashcup
Michael said:
Huh?
Michael
I don't want to stick my head in between the high-voltage electronics
and the CRT to see it more closely.
K
Ken G.
You dont need to discharge anything to do some soldering . The charge is
held up under that big suction cup on the picture tube . Simply turn the
set off and wait a few minutes for the filter capacitors to discharge by
themselves , turn the board over then solder .
In some cases when you walk up to a tv and touch metal parts you may get
a static zap just like you do from the car door or door knob in your
house .
C
CJT
house .
That "big suction cup" has a wire extending from it to the HV section.
Touching any bare section of that wire (although there shouldn't be
any), or of the parts in the HV section to which it's attached, can
give you a big surprise.
The picture tube itself holds the charge.
C
CJT
That sounds like a recipe for problems later, when bits of steel wool
left behind cause further shorts. Besides, putting steel wool on a
board containing capacitors that aren't fully discharged already can
discharge them through inappropriate paths.
S
Sam Goldwasser
Responses like this are not constructive and downright dangerous.
Simply leave the TV off overnight. That should discharge any capacitors
that would affect soldering on the mainboard. The only possible remaining
charge may be on the CRT anode but that only goes to the flyback and you
should not need to disconnect it. And, that will almost certainly be
discharged by then in any case.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
S
Sam Goldwasser
In nearly all CRT TVs and monitors less tha 30 years old, it goes directly
into the flyback and bare sections would be extermely unlikely.
H
Homer J Simpson
Unless the ground to the outside of the kine is disconnected. Not a good
thing to touch if you are standing on the ledge of a second floor window.
James Sweet
the problem.
Thanks in advance!
Just get in there and solder it, if the set has been unplugged for a few
days there's no risk.
S
Sam Goldwasser
I'm not sure I'd want to test it out this way, but in principle, if the
ground only were disconnected after the set was turned off, there would
be no voltage between it and ground.
H
Homer J Simpson
True, but when it is run that way and you just turned it off to twist the
yoke . . . . .
I think a lot of the reponses so far have been attempts at humour.
Possibly because you say youre very experienced yet dont know how to
discharge a psu cap or the tube eht. No, you cant rely on them to self
discharge over a day or so. Since youre experienced, figure it out.
NT
H
Homer J Simpson
He made his skill level clear and the best advice for him is to not try.
the problem.
S
Sam Goldwasser
yoke . . . . .
HeHeHe... If it's run with the CRT ground disconnected, that's a different
story. :)
B
bz
[email protected] wrote in
Go to the library. Get an older copy of the Radio Amateur's Handbook. It
should show you how to make a tool consisting of a wire, a wooden dowel, and
a resistor, that can be used to safely discharge high voltage capacitors.
These devices were called 'crowbars' because that is what they essentially
were, a crowbar with a heavy wire that connected it to ground.
The operator would turn off the power, hang the crowbar on the high voltage
line, grounding it, and work on the equipment, secure and safe. IF someone
accidently turned on the power without removing the crowbar, it would blow
fuses.
Nowdays, a circuit that shorts the output of a power supply to ground in case
of overvoltage output of the supply is called a 'crowbar' circuit, for
reasons that should now be clear.
bz 73 de N5BZ k
please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
infinite set.
[email protected] remove ch100-5 to avoid spam trap
M
Michael A. Terrell
You are describing a "Shorting Stick" which is a safe way to discharge
a HV power supply to service the equipment. It was also used in
broadcast transmitters, in case the safety interlocks failed. A crowbar
is not current limited, it is a fail safe shutdown circuit, and you can
expect damage if it is triggered.
fuses.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
