Is there any adaptor or such that can convert a solder terminal component to a loose wire to easily connect to a breadboard? Or is there a special wire where you solder one end and then other end is a breadboard wire?
For short distance use a cut resistor leg to be plugged into the breadboard.
For longer distance solder the needed length wire to a cut resistor leg to be plugged into the breadboard.
or the cheapest spool of stranded 24 or 26 AWG wire you can find.
better yet if you can find some of the stuff where the insulation melts off onto ones' hands the moment the wire gets sufficiently warm (but one may find luckily it also washes off in warm water).
