Solder Sucker
Discussion in 'General Electronics Discussion' started by Andy Twose, Aug 18, 2017.
  1. Andy Twose
    Andy Twose
    13
    Feb 16, 2016
  2. Minder
    Minder
    3,066
    657
    Apr 24, 2015
    I have used the simple pumps as you show in the past, but I am not sorry I picked up a hollow nozzle iron type with a suction bulb, like night and day to use.
    These were sold by Radio Shack in N.A.
    I am surprised that no one has replicated them, (maybe they have?).
    If you can find one, I highly recommend it.
    https://www.radioshack.com/products/radioshack-45-watt-desoldering-iron
    M.
    Andy Twose and bushtech like this.
  3. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    Those simple solder suckers are fine for occasional use but I'd recommend you get a short length of silicon tubing to slip over the tip - saves the end on the sucker and gets you closer to the solder, making a much better job of sucking it off (giggidy) .
    bushtech and Andy Twose like this.
  4. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    I wouldn't use those suckers at all !
    Their main disadvantage is they tend to pickup the pad from the PCB with the solder and all.
    Use solder-wick from a good brand,
    it will save your PCBs from harm and...:eek:
    Will save you a lot of heartache.
  5. Minder
    Minder
    3,066
    657
    Apr 24, 2015
    This is the advantage to the hollow iron type as heated pressure is kept on the foil and only the through hole or pad is evacuated.
    Never had any problems so far.
    M.
  6. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    The one you posted is fine to use.
    There is the professional version with "auto" vacuum as well.
    I was referring to the cheap manual push button ones the O.P posted ,
    sorry for not being clear.:(
  7. HellasTechn
    HellasTechn
    1,556
    215
    Apr 14, 2013
  8. HellasTechn
    HellasTechn
    1,556
    215
    Apr 14, 2013
    Hakko is indeed a fine brand. The ZD-985 is of about the same quality but alot cheaper i think.
  9. Audioguru
    Audioguru
    3,153
    698
    Sep 24, 2016
    Cheap Chinese pcb's use chewing gum to adhere the copper to the board.
    Cheap Chinese soldering irons do not have temperature control so they are way too hot.
    My pcb's are made locally and my soldering iron has controlled temperature. Then my solder sucker sucks solder, not the pads.
