solder alternatives?
Discussion in 'Misc Electronics' started by Mark Haase, May 31, 2004.
  1. Mark Haase
    Mark Haase Guest
    hey all--
    i have a 4 digit LED which has three pins broken off, as well as a
    68HC11 board which has a transistor that broke off. in both cases, the
    leads severed right at the edge of the package, so there's no wire
    sticking out to reattach to. i can't figure out how i would solder it
    back together, i'm guessing its impossible.
    i've seen/heard of some solder alternatives, like adhesives that are
    very conductive. can anybody comment on the appropriateness of these to
    my situation and/or recommend a good brand to buy.
    any and all help is much appreciated,
    mark
  2. --------------
    Replace the transistor, but the LED display can be resoldered by
    cutting into the plastic around the lead and soldering, or replace
    with 4 separate digits, or fish another one out of a used clock or
    somesuch.
    -Steve
  3. Andre
    Andre Guest
    Yup, that'll work :) my personal preference is to use a Dremel (tm) to
    grind away the plastic rather than cutting it, it does less damage if
    you are careful. Wear SAFETY goggles!!!
    The other repair trick I have used is that "conductive" copper/silver
    paint (Electrocure) used for repairing car demisters. Just the thing
    for reconnecting severed leads on thin film solar cells, these worked
    100% of the time unlike the circuitry connected to them ;-)
    -Andre
    "Bother" said Pooh, as he was flash-frozen by the superstorm...
