Solartron 7150 Manual needed.
Discussion in 'Electronic Equipment' started by njkenworthy, Oct 27, 2004.
  1. njkenworthy
    njkenworthy Guest
    Looking for an E-copy of a Solartron 7150 manual OR a clue as to why the
    unit is only responding to the keypad in columns as opposed to as it should
    as a matrix. ie keypad is 3col x 4row matrix but only 3 functions available,
    all keys in one column produce same reult.
    All functions available via GPIB and all scales/ranges in good order.
  2. Joerg Hau
    Joerg Hau Guest
    Hi
    The User's Manual does not say anything about such a state ... in
    other words, this is not "expected behaviour". If the 7150 is _not_
    in local lockout state, every single key (mode/range settings etc)
    should react as you expect them to do.
    Just to be sure: did you disconnect it from the GPIB bus? You did not
    accidently - via GPIB - send it into calibration mode (where it would
    no longer react to the front keys either)?
    Cheers + HTH,
    - Joerg
