M
Mario,South Africa
Hello everyone. Anybody who knows if the following is possible?
I am a Paraglider Pilot (Glorified parachute) and I am busy with my
Paramotor license. (A Paramotor is a paraglider with a small engine+prop
(0.8m - 1.3m) carried on the pilot's back which gives 40-50Kg force with a
12-20KW engine. The whole thing weights about 20-25Kg). My idea is to
replace the internal combustion engine with a electric one of similar weight
and power. Now If you don't know anything about paramotors - I only need
12+Kw (and 40 or so Kg of push) for a minute or so during take off. In
normal flight 4-8Kg of force is enough to keep me in the air ! Because of
this the internal combustion engine is build very light with no proper
cooling (does not need to anyway). I have found a suitable engine within
minutes on google (15KW max for a few minutes 7KW continuous at 36v (48v)
and only weights 10Kg !) Also the propeller can be made bigger to increase
efficiency (a 1.5m - 1.8m max which will give approx. 6Kg - 8Kg force per
Kw) I intend on using a super cap for the 30 seconds or so of extra take off
power (they are plenty within the weight limit which stores enough for the
short time) . The only thing I don't have is a light, flexible solar panel
aprox. 3x9m to work into the upper surface of the glider/wing. I thought the
power can be carried thru the control lines to the engine/cap. It must be
around 12% to 15% efficient to give me the 2.5Kw or so I need for the
electric motor which in turn will convert 90% or so to mechanical energy
(turning motion for the prop). Any ideas?
