Solar Powered Battery Charger/Conditioner
Discussion in 'Electronic Design' started by [email protected], Feb 16, 2007.
  1. Guest
    Hi Folks,
    I hope you can help me. I'm trying to design a battery charger/
    conditioner that runs off solar power. I need to do this because my
    motorcycle is stored 200 yards from my house and has no available
    mains power. I'd like the circuit to charge and condition my battery.
    Any help will be greatly appreciated
    Stephen Connor
  2. On 16 Feb 2007 01:09:47 -0800, in sci.electronics.design
    try here for a kit
    http://www.mrsolar.com/page/MSOS/CTGY/indkits
    but all you need is a suitably sized solar panel and a shunt regulator
    at
    rswww.com
    RS Stock no. 194-082
    download the data sheet
    or try this site, if you want to DIY
    http://ludens.cl/Electron/solarreg/Solarr~1.htm
    martin
  3. default
    default Guest
    Put some constraints around it. Do you want something that uses great
    big expensive panels that generate enough to charge a dead battery or
    just to keep the battery from discharging when the bike isn't being
    used. How large is the battery in ampere hours?
    I put some flexible solar panels on my gas tank. One blocking diode
    to keep it from discharging at night. Never had to resort to a
    charger as long as the bike was parked in sunlight. 100 ma output, 15
    volts open circuit, battery was a 14 amp hour size. The bike probably
    got about 4-5 hours of sun a day.
    For my sailboat I used two 1 amp panels, and a shunt type regulator to
    limit the voltage to 14.5. Ran the radio and lights on it and started
    the motor which had an alternator. More than enough power. Car size
    50 AH battery
    One thing to keep in mind is that a panel is only as good as the
    weakest cell - shading one cell will dramatically drop the power and
    may make the difference between some charge and no charge. Two small
    panels (and two blocking diodes) will be better than one if you can't
    predict where the shade will be.
  4. joseph2k
    joseph2k Guest
    At many auto outlets there are solar powered battery chargers for
    infrequently used vehicles. Use one of those (a small one for the small
    battery of a Motorcycle).
  5. jasen
    jasen Guest
    6V?
