Solar Power Lantern
Discussion in 'Troubleshooting and Repair' started by sirvlad, Apr 30, 2013.
  1. sirvlad
    sirvlad
    3
    Apr 30, 2013
    I have two solar powered lanterns that got damaged. The boards were badly corroded so I removed all the components from the boards and cleaned them. I purchased new components and reassembled the boards but they don’t work none of the LEDs light up, i have tested the LEDs individually and they will light with voltage applied. I must have messed up somewhere but I don’t know. Perhaps the components I purchased were the wrong ones?
    The board is powered by 3x AAA rechargeable batteries and there is a solar panel attached that recharges the batteries
    Here is a parts list:
    2x 10ohm resistor
    1x 270k ohm resistor
    1x 128k ohm resistor
    1x 150ohm resistor
    1x Diode (markings: 1N5818GW / replacement: NTE585)
    2x Transistor (markings: S8050 C331 / replacement: NTE159)
    Here is a picture of the traces on the board (**Note: The broken traces on the top of the board and inbetween the transistors have been repaired**)
    [​IMG]
    Here is a picture of the front with traces painted over
    [​IMG]
    What did I do wrong? Are the replacement transistors wrong?
    Thanks for any help you can give me.
  2. (*steve*)
    25,496
    2,837
    The first thing that stands out to me is that an S8050 is an NPN transistor and an NTE159 is PNP.
    If the transistor was in fact a 2SC331, then that's NPN too.
    I'd be looking at replacing the NTE159 with a @n2222 or a BC548, or some other general purpose NPN transistor.
  3. sirvlad
    sirvlad
    3
    Apr 30, 2013
    Thank you, i was just relying on the guy at the parts counter for the transistors. i don't know much about electronics i guess just enough to be dangerous. i have seen other solar power lamp schematics that use a BC548 so i will order some of those.
  4. sirvlad
    sirvlad
    3
    Apr 30, 2013
    Thank you again steve, i went back to the store and got a BC548 equivalent and they work perfectly :)
Similar Threads
Loading...
