Lawrence1986
- Apr 29, 2014
- 2
- Joined
- Apr 29, 2014
- Messages
- 2
Before I explain my problem I should probably say that I'm only starting out with electronics so I apologise now for any mistakes or inaccuracies within my post.
The Project:
I've got four 5.5v 180mA solar panels. These all have blocking diodes soldered onto them. They are connected up in series. When tested with a multimeter all 4 produce around 7.5v indoors.
I connect them to a 7805ct 5v regulator (http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=191152529292)
The solar panels are connected to the input and the ground pin goes back to the solar panels - connection.
When testing them with the multimeter the input of the regulator shows around 2.5v and the output shows 0v. But when I disconnect the panels they still read about 7v so I know they are generating enough voltage. I've also connected a female usb port to test which is shown in the image file attached.
Ive also tested the voltage regulator using my switch mode power supply and on this it functions correctly and drops voltage from 7 or 12 volt down to 5v.
Any help would be greatly appreciated.
Regards,
Lawrence
The Project:
Regards,
Lawrence
