Solar panel related question -- help please
Discussion in 'Electronic Design' started by [email protected], Dec 17, 2012.
  1. Guest
    Could the solar panel/power gurus on this ng please help ?
    One important parameter related to solar panel is the
    "panel generation factor" defined as:
    Panel Generation factor(PGF) = Collection Efficiency x Average solar radiation in least sunny month.(kWh/sq m/day)
    What exactly is "collection efficiency" ? Is it the solar
    panel efficiency ? For example, the PGF of most of
    Europe is 2.96 -- given that a standard solar pahel
    can convert just 15% - 18$ of light energy to electrical
    energy, what exactly is the "collection efficiency"
    Any hints, suggestions would be of immense help. Thanks
    in advance.
  2. mike
    mike Guest
    suspect you'd get a better answer in a better group.
    Anything with solar in the name
    or alt.energy.homepower.
    Or get an answer from the panel vendor.
    I've gone looking for that definition in the past, and again today.
    I never found anything that approached a definition.
    I chose to ignore it and do the calculations.
    Are you sure you're quoting the right number?
    Your 2.96 sounds more like an annually averaged daily insolation than
    the least sunny month. Multiply that by 20% collection efficiency
    (round number)
    gives more like 0.6 kWh/day/m^2 for energy generated averaged over the
    year...much less in winter.
    Given the way things tend to be measured at optimum, I'd expect that
    you'd need MPPT and optimum sun tracking and no buildings or trees to
    get that.
    And remember that the panel is rated with no rain or snow or or dust on it.
    And no bird crap or smog or smoke or nothin'.
    And no losses in the conversion to what you actually need.
    Local micro-climates can have a siginificant effect. Those won't show
    up in average insolation numbers.
    Solar sucks if you have any alternatives.
  3. Phil Allison
    Phil Allison Guest
    "mike"
    ** The only fact you need to really know.
    ..... Phil
  4. Robert Macy
    Robert Macy Guest
    ....my opinion:
    Collection Efficiency = (Electrical Energy generated in kW) / (Energy
    'available' in light per sq m).
    Although, don't know why it is called 'collection efficiency' instead
    of 'conversion efficiency'. Maybe there is one more factor involved
    which would include reflectors and/or lensing.
    There is a maximum amount of energy in sunlight per sq meter. From
    memory, it was around 0.35 W per sq cm - measured for straight in sun
    at the equator.
    As I said, it is my opinion that CE relates to how well you can
    convert that supplied energy into electricity. Also, from memory I
    remember solar cells at the time being in the range of having 1-3%
    conversion efficiency. But, absolutely not even near 10%. Had
    something to do with the limited spectral sensitivity range of the
    silicon. The sunlight had a lot of energy in frequencies the silicon
    couldn't 'see'.
  5. Robert Macy
    Robert Macy Guest
    After reading wiki, it appears that the 0.35W number more reflects
    what to expect from a solar cell.
  6. The number I always heard was 1kW/m^2 = 1mW/mm^2
    (1 mm^2 is nice for laser stuff, since its about the size of a laser
    spot, and also about the size of your eye pupil.)
    George (millimeter) Herold
  7. tm
    tm Guest
    That would give 3500 watts per m^2. Fails the reality check.
    I think the insolation runs about 1 kw / m^2 at the equator (I did not
    google it though).
  8. That's about right, although I take issue with 1mW/mm^2. ;-)
    Jeroen (SI) Belleman
  9. Jeff Layman
    Jeff Layman Guest
    Correct, but that's only at noon, with the sun directly overhead.
  10. Grin, no Jeroen was just poking fun at me for an earlier post about
    units. (I was hoping to 'twig' him with mW/mm^2.)
    George H.
  11. Guest
    A particular solar panel product will specify the output power , Pout, measured at standard test conditions (STC) which are defined as 1000 W/m^2, 25oC cell temperature, and 1.5 Atm air pressure. They also specify a derating factor for the variation of Pout with temperature, usually something on theorder of -0.5%/oC, and a tolerance for the output power. The PGF is an installation specific conversion factor specifying the daily panel output electrical energy in Wh, or kWh, per watt, or kW, unit of solar panel output power. The specifics used to compute the PGF are average cell temperature, average irradiation of the cell in units of 1000 W/m^2, average meteorological conditions, average insolation. Once the PGF is known, all you have to dois divide the minimum daily energy required of the solar (adjusted for obvious system losses like inverter efficiency, charging efficiency, panel pointing errors, panel dirt accumulation...) by the PGF to derive the total required panel STC power. Then divide by the per panel STC output to derive the number of panels.
  12. Guest
    On Monday, December 17, 2012 11:40:45 AM UTC-5, Jeff Liebermann wrote:
    It's not that deep, it's a number used by installers in fixed geographic areas. They can lump all the stuff that stays the same on all their jobs intothe PGF. Things like the efficiencies of their inverters, presumptions of cable losses from just eyeballing the building dimensions, the low ball worst case insolation, the charging efficiencies of the battery system if any,typical panel power output reductions to be expected from soot, pollen or whatever in their area, etc... all that junk is pretty much the same every time. The only custom work that needs to be done is to size the energy requirements of the customer. Then PGF makes the energy->panel power conversion.. Manufacturers don't spec energy, they spec power, and systems are designed around energy and not power. So PGF gets them there.
  13. Guest
    Thanks for the links. As the 'panel generation factor' is
    used to determine the number of solar panels to be used at
    a given site, the following is an alternative scheme that
    some of us have put together to determine the number of
    panels at the same site.
    Let us suppose that the electrical parameters for a given
    panel are:
    Wp=75 Watts
    Isc=4.8 A
    Voc=21.4 Volt
    Im=4.4 A
    Vm=16.8 Volt
    Active solar panel area AA = 0.605 sq. meter
    Define FF = (Vm*Im)/(Voc*Isc) = 0.718
    Then, at STP
    Efficiency= (Voc*Isc*FF)/(It*AA)*100% = 12.36% (at STP It=1000 Watts per sq. m)
    Now let us suppose that the average insolation at the site
    is: 500 Watts per sq. m
    Actual efficiency at 500 Watts per sq. meter = 12.36*0.5/100.0 = 0.0618 = 6.2 %
    Power produced by the single panel=0.062*500*AA(0.605) = 18.75 Watt per hr
    So for a 8 hour period(brightest possible sunlight), the total
    power generated by the panel = 8*18.75 = 150 Watts per day
    So if the total power requirement is ww Watts, the total
    number of panels is ww/150
    How does the reasoning look like ? Are there any glaring
    mistakes ? Please provide your comments
  14. Robert Macy
    Robert Macy Guest
    gaccckkkk!!!
    slipped a 'few' decimal points.
  15. Robert Macy
    Robert Macy Guest
    Don't forget the cost of the security system to thwart 'solar panel'
    thieves.
  16. amdx
    amdx Guest
    Snip
    Also use the proper derating factor on performance statistics gleaned
    from any solar system owner, that spent his hard earned money.
    Mikek :)
  17. mike
    mike Guest
    Yeah, but, there are also those who just want a little target practice.
  18. mike
    mike Guest
    Back when stimulus money was flowing like water down a rat hole,
    I talked to a number of solar vendors.
    None of the offerings stood up to simple questions.
    The best looking one was a lease program. You saved money on
    your electric bill and used that difference to pay the lease and
    you came out ahead. No-Brainer...but wait.
    Do you base it on actual savings?
    NO, it's predetermined assuming you were one of the first 20 people
    out of the 10,000 who applied for the subsidy within milliseconds of the
    offering. And there was no guarantee that it would be available next year.
    Took me half an hour of probing the vague deflected answers
    to get to that point.
    I asked for the free site audit...they must have lost my application.
    Never trust the numbers from anyone who's trying to sell you something.
    Talking to actual owners is way better...if you can find them.
    But that's not foolproof. The placebo effect is very strong.
    When I had my house weatherized, I noticed a great savings in energy.
    Over time, as I settled back into my old ways, the savings decreased.
    And I actually measured it. Most people are just guessing and feel
    better if their guesses support their decisions.
    There were a lot of weatherization subsidies.
    I'm sure it's better for the planet, and the children, but based on the
    payback period, I'd probably not have done it on my own dime.
    Same for solar. It's great if you can get someone else to pay for it.
  19. mike
    mike Guest
    Problem with solar is that it takes too much space. Even at 100%,
    it's still too big to be practical...until we scale back demand
    about a hundred years.
    Anybody with half a brain has invested their life savings in Ecat.
  20. Guest
    You can put that in the same category as the those ripoff hydrogen generation modules claiming to boost gas mileage- power for electrolysis derived from alternator- mmm yeah.
