I'm a newbie to creating circuits, though I can happily put together pre-designed ones!
I have a need to run two PC fans (12V 0.11A) from a 12V solar panel. There is nothing clever needed - simply put - the sun shines, the fans are on!!
Now - the rating for the panel is as follows
Peak Voltage 17V
Peak Current 0.59A
Peak Power 10W
I need to create a board which will expose two pins for each fan (and maybe a 3rd and 4th for future expansion). My fans already have 2-way 2.54mm kk PCB plugs attached...
I was thinking of somthing like this - but I might be wrong! (This is for Stripboard with the copper strips running vertically)
(From Solar Panel)
+--R---L--- + -
+ xxxxxxxx -
+--R---L--- + -
+ xxxxxxxx -
+--R---L--- + -
+ xxxxxxxx -
+--R---L--- + -
R being a resistor, L being an LED, and the + - being the PCB interconnect pins that the fans will plug into. (the xxx's are when I cut the copper strips to keep each row separate)
I hope thats clear enough, though I fear its probably not! I'd like to know if this is enough to go on, and what the value and safe power rating of R would be... I'm not sure I've got the LEDs either, so I can actually do without them, I assume this won't affect the value of R too much?
Hope someone can help, cheers...
Peak Voltage 17V
Peak Current 0.59A
Peak Power 10W
(From Solar Panel)
+--R---L--- + -
+ xxxxxxxx -
+--R---L--- + -
+ xxxxxxxx -
+--R---L--- + -
+ xxxxxxxx -
+--R---L--- + -
