Solar panel controller
Discussion in 'General Electronics Discussion' started by bigone5500, Apr 9, 2014.
  1. bigone5500
    bigone5500
    712
    120
    Apr 9, 2014
    I want to build a controller for a couple solar panels I have. They are 10w and produce ~20v each in full sun. I want to use this to charge a 12v sealed lead acid battery. I would like it to charge to a set voltage and shut off. This controller may also be used on small lawnmower batteries too which I assume are basically the same. I have tried a few basic schematics but they did not work as I had anticipated.
  2. (*steve*)
    25,480
    2,827
    Google for MPPT Solar Charger. It may be cheaper to buy one, but that won't allow you to change voltage.
  3. bigone5500
    bigone5500
    712
    120
    Apr 9, 2014
  4. (*steve*)
    25,480
    2,827
    That's a 10A controller, suitable for a 120W panel. You may be able to find a cheaper option for (say) 5A. But in any case it is reasonably cheap.
  5. bigone5500
    bigone5500
    712
    120
    Apr 9, 2014
    Thanks.
  6. bigone5500
    bigone5500
    712
    120
    Apr 9, 2014
    I bought a solar controller today from harbor freight that can handle 100w or 7A.
    My question now is that when I connect the two panels together in parallel, I will need a blocking diode. How do I calculate what size diode I need. These two panels produce .6A current each at 20vdc and have 10w output in full sunlight.
  7. (*steve*)
    25,480
    2,827
    If the panels are oriented in the same direction and will not be shaded, you will not need any diodes.
    If you really want to use some diodes, I would recommend 30V 1A schottky diodes. They will waste the minimum amount of power.
  8. bigone5500
    bigone5500
    712
    120
    Apr 9, 2014
    Ok. I will try them out without a diode. I thought you had to have one to keep them from bleeding into each other. Thanks.
  9. (*steve*)
    25,480
    2,827
    As long as they are similar (i.e. same make and model) panels in the same plane (and facing the same -- not opposite -- direction) and you do not expect one to be in shade when the other is not, they will not leak charge into each other.
    Is there a link to the charger you bought?
  10. (*steve*)
    25,480
    2,827
    OK, that may not be an MPPT charge controller, but it should still do the job.
    I'm a little concerned that the instructions tell you to disconnect the solar panels if the green light comes on though...
  11. bigone5500
    bigone5500
    712
    120
    Apr 9, 2014
    It was dirt cheap so if it doesn't do the job I'm not out much. I will just spend a little more next time.
    About the instructions, I think it may mean that if the unit is over charging the batteries then disconnect it...I hope...
Similar Threads
Loading...
