D
Dan K
I just want a detector to tell if its day or night. Easy, right?
I started out with a photo resistor (CdS Photoconductive Photocell I
believe) in a voltage divider feeding a comparator. Worked fine on the
bench. Worked fine outside the first day. Stopped working the second day
(failed to detect night) and when I brought it in and tested it, the photo
resistor was measuring a whole new range of resistances. For example it
originally measured 1M ohm dark and 100k ohm light...after a day in the sun
it reads 100k ohm dark and 10k ohm light. I believe this is due to
saturation, but see no mention of this in a data sheet.
Next I tried a photo transistor. Simple enough... light hits transistor,
transistor turns on. This worked fine for a few months, however a couple
days ago it failed to detect dark. I swapped out the detector and brought
the faulty one in to test. The transistor was on all the time...acting like
it was in bright sunlight, even when it was in total darkness. This was
after it had been in the dark for at least an hour. A day later, the
transistor was working normally again. I believe this is also a saturation
problem, and the device seems to recover after a while, but I'm looking for
a solution that works all the time, not just most of the time. The data
sheets don't seem to mention this problem, or if they do I'm not
understanding what they are saying. Could someone help? I can switch
sensors if thats the problem.
Dan
Dan
