W
William P.N. Smith
I thought my builder had the solar hot water thing under control, and
he thought I was doing it, so now I've been saddled with another task.
Sometime in the next month I've got to get a solar thermal hot water
system specified and delivered. Yikes!
Anyone have any suggestions for brands, vendors, or types? This will
be used in a non-freezing environment, and I'd like to get as much
storage as possible.
Because of homeowner's association rules, the solar panel must be at
ground level, and I'm thinking of having an 'automatic' system that
will use a couple of 20W solar electric panels I've already got,
running a circulation pump whenever the sun shines. Will this work,
or must I have a differential thermostat as well?
Can I just use any random electric hot water heater(s) for storage,
and run the heated water backwards thru them with a pump, of do I need
to remove/extend the drain valve to take cold water from the bottom of
the tank?
Anything I'm forgetting?
Many Thanks in advance!
the tank?
