Solar Heating?
Discussion in 'Photovoltaics' started by David Dawson, Sep 26, 2006.
  1. David Dawson
    David Dawson Guest
    Is there anone who has solar heating?
    If so, what type?
    I read that it is a maintenance nightmare...
    Anyone found a solution?
    Thanks.
  2. Mary Fisher
    Mary Fisher Guest
    Where are you?
    Mary
  3. daestrom
    daestrom Guest
    You might try alt.solar.thermal (I added it in to this reply). Yes, there
    are several folks that have used solar thermal heating of one form or
    another. As far as maintenance, I think you'll find it's "all over the map,
    from easy to nightmare".
    daestrom
  4. David Dawson
    David Dawson Guest
    I am in Vancouver, British Columbia.
    Did you have some specific advice?
    Thanks.
  5. David Dawson
    David Dawson Guest
    Thanks!
    (How come I overlooked it?)
  6. daestrom
    daestrom Guest
    The way I heard it...
    "wrestling with a pig just gets you both dirty and it annoys the pig"
    daestrom
  7. SJC
    SJC Guest
    I would say an air system would be lower maintenance
    than the water system. Air heat takes a thermal mass to store.
    Water is the thermal mass in a water system.
    I would say that an air system is simpler to build and install.
  8. Mary Fisher
    Mary Fisher Guest
    I wondered if you were the David Dawson who went to Canada from England -
    the beekeeper ...
    Mary
  9. David Dawson
    David Dawson Guest
    No,
    I went from Canada to England when I was 4 and came back when I was 5.
    I don't keep bees, it would be a bit tricky in the apartment ;)
    I don't mind bees though.
  10. Mary Fisher
    Mary Fisher Guest
    Easy, actually :) But you might have been the David I knew.
    Mary
