Solar Charge Controller: add Load Output?
Discussion in 'General Electronics Discussion' started by kanuck, Jun 3, 2013.
  1. kanuck
    kanuck
    3
    Jun 3, 2013
    Greetings All!
    I recently picked up a Coleman 7-amp Charge Controller as part of a kit (with 40W solar panel). At first glance, it appears to offer only Panel:IN and Battery:OUT connectors, but since I've a similar controller that also offers a controlled Load:OUT (auto shuts off when battery drops below a specified voltage), its lopsided layout got me curious. Sure enough, when I popped it open I found an unused Load connector!
    It looks ready to go to me, but I'm no electronics wiz. Can you tell whether setting up a similarly controlled Load:OUT is really as easy as soldering on connectors at the marked L+ and L- spots?
    Front:
    [​IMG]
    Back:
    [​IMG]
    Thanks in advance!
  2. CDRIVE
    4,960
    652
    May 8, 2012
    Do you have a schematic?
    Chris
  3. (*steve*)
    25,496
    2,837
    Surprisingly, the answer may be YES.
    It appears the transistor used to switch the load has been populated on the board.
    Perhaps it is more expensive to produce a board without it?
  4. CDRIVE
    4,960
    652
    May 8, 2012
    Steve, what's the component marked "F"? One leg is connected to "L-".
    Chris
  5. davenn
    davenn Moderator
    13,833
    1,950
    a fuse would be the obvious choice ;)
  6. CDRIVE
    4,960
    652
    May 8, 2012
  7. davenn
    davenn Moderator
    13,833
    1,950
  8. CDRIVE
    4,960
    652
    May 8, 2012
    That would indicate that the fuse isn't currently used. That's very odd.
    Chris
  9. kanuck
    kanuck
    3
    Jun 3, 2013
    Thanks Gentlemen!
    Here's hoping you're right. Guess I'll make the connections and give it a shot, try testing the system for a low charge disconnect. Will post the results.
    Good question about the F piece. I'll check it for markings when I pull it apart again.
    Thanks again...
  10. kanuck
    kanuck
    3
    Jun 3, 2013
    It's been forever... just wanted to post that I connected a Load: OUT feed and it worked as predicted. BONUS!
    Thanks for all the help!
