Solar cell charger
Discussion in 'General Electronics Discussion' started by Karthik rajagopal, Jul 10, 2016.
  1. Karthik rajagopal
    Karthik rajagopal
    241
    9
    May 9, 2016
    Hi all,
    I wanted to make a cell phone charger for my project for which I was searching the circuit on Google. What I noticed that the wires from the solar panel are connected to the voltage regulator and to the cell phone. My doubt is that while a cloud is passing the sunlight will be blocked by it there by reducing the voltage from the solar panel and there will be a drop in the input voltage of the regulator which will affect the phone charging. If the passing of the clouds are frequent won't the phone get damaged as there is no stable output voltage?
    Thanks in advance.
  2. BobK
    7,682
    1,688
    I doubt that it would get damaged any more than it would get damaged if plugged into a mains powered charger and the power went off. But you might want to use a circuit that cuts it off completely when it cannot produce something close to 5V output. A continuous 2 or 3V might be handled badly by the phone.
  3. Karthik rajagopal
    Karthik rajagopal
    241
    9
    May 9, 2016
    Will the voltage regulator operate when the input voltage is less than 5 v if I am going to use a 7805?
  4. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    A 7805 needs about 2V to operate so needs 7V input.
    There are low drop out regulators which need less than 2V.
  5. BobK
    7,682
    1,688
    When the input is insufficient, the regulator will put out a lower, unregulated voltage.
  6. Karthik rajagopal
    Karthik rajagopal
    241
    9
    May 9, 2016
    So what kind of a regulator to use. can u please tell me a voltage regulator with lower voltage drop?
  7. Chemelec
    Chemelec
    291
    47
    Jul 12, 2016
    What is your Solar Panel's Voltage and Current Rating?
  8. Sunnysky
    Sunnysky
    488
    126
    Jul 15, 2016
    Vbat charge =75% Voc from PV ( open cct) is near ideal +5% for bright and -5% for dim
    If the array is small on a cloudy day then you need large mirrors to reflect more sky diffused energy to PV for slight improvement, otherwise SOL.
    The phone will regulate the voltage if impedance of PV s low enough.. V/I=Z. i.e. current source is high enough, otherwise phone will load PV and drop voltage too much and thus also PV efficiency which is near ideal at 75% then efficiency drops with PV voltage
    [​IMG]
  9. Sunnysky
    Sunnysky
    488
    126
    Jul 15, 2016
    dont use 7805, choose proper size PV array and voltage
  10. Karthik rajagopal
    Karthik rajagopal
    241
    9
    May 9, 2016
    My solar panel voltage rating is 7v and current rating is 100 mA.
  11. Karthik rajagopal
    Karthik rajagopal
    241
    9
    May 9, 2016
    Then can you suggest me voltage regulator for this please.
  12. Chemelec
    Chemelec
    291
    47
    Jul 12, 2016
    I would just put a 1N4001 Diode in series with the panel and than connect it directly to your phone.
    This diode will reduce the voltage by 0.6 volts and it will also prevent the battery from discharging back into the solar panel, when there is no sun.
  13. Karthik rajagopal
    Karthik rajagopal
    241
    9
    May 9, 2016
    The battery will get damaged as the voltage given by the solar panel is 8.5 v and the required voltage is 5 v.
  14. Sunnysky
    Sunnysky
    488
    126
    Jul 15, 2016
    is that the PMT load voltage or open cct Voc? PV is a current souce and phone has a V regulator
  15. Chemelec
    Chemelec
    291
    47
    Jul 12, 2016
    NOT LIKELY to damage anything.
    The Output Current is NOT HIGH Enough.
  16. Sunnysky
    Sunnysky
    488
    126
    Jul 15, 2016
    unless you define your phone and intended solar panel, the rest is pointless. the reverse blocking diode protects the PV and battery from drain, which may already exist in the phone.
    yes clouds will lower input power by solar power diffusion.. forget about implementation details until you define what you are working with, or simply phone model and desired charge time in hours and location availability of solar power.
