Solar Battery charger
Discussion in 'Power Electronics' started by kevinos, May 27, 2013.
  1. kevinos
    kevinos
    3
    May 27, 2013
    i am building a battery charger of 13.8 DC volt output from and im using a diode to protect the regulator but now i was told that if you use a diode it will consume 0.6 volt
    woud this circuit still charge my 12 volt battery? :confused:
  2. Harald Kapp
    11,513
    2,651
    It probably will, up to ~13.2V
    A lot depends on the circuit of the charger, the type of battery used and the charging scheme employed..
  3. kevinos
    kevinos
    3
    May 27, 2013
    how do i post an image here ???
  4. Harald Kapp
    11,513
    2,651
    Go advanced, use the paperclip symbol to upload an atachment. Copy the link (URL of the attachment) from the upload box Use the "insert image" button (second row, 5th from right) and paste the link there. You can also paste links to images on other platforms (e.g. flickr), but make sure the pages you link to are publicly accessible.
  5. kevinos
    kevinos
    3
    May 27, 2013
    thank you
