Hi there, I'm a 3rd year Aeronautical Engineering student at Brighton University (UK) currently working on my dissertation, which is a solar powered model aircraft.
I am not the best with electronics so I apologise if I'm a little dense not the topic.
My aircraft will have an array of solar cells producing around 2.5A at 12V
I will be using a 3s Lipo battery 1100mah 11.1V
The motor will be drawing more power than the solar array provides, so how can I draw all the current from the solar array and the rest that is needed from the battery?
I was going to use a maximum power point tracker but as I will be using more power than I am producing I feel it is an unnecessary weight.
Any help would be greatly appreciated, as it is holding my project up but it is not an important aspect I am being assessed on due to being an Aero engineer.
Many thanks, Sacha.
Many thanks, Sacha.
