Software for block diagrams
Discussion in 'Electronic Basics' started by Melodolic, Jun 7, 2006.
  1. Melodolic
    Melodolic Guest
    Any recommendations for software that can be used to sketch block diagrams
    of circuits? Doesn't have to be fancy - usability is more desirable than
    lots of features.
    Cheers,
  2. Roger
    Roger Guest
    I use the generic drawing functions in my schematic editor, has the
    advantage that I can easily throw in electrical symbols in boxes or
    whatever. Many schematic editors have block diagram like symbols ready
    made.
    Worth noting that most EDA packages have evaluation versions with
    limited capabilities such as size of board, number of pins etc., should
    not be any problem if you want to make a block diagram.
  3. JeffM
    JeffM Guest
  4. Melodolic
    Melodolic Guest
  5. Melodolic
    Melodolic Guest
    Yup, I recently got the freebie version of Eagle. I'm just having a look
    through the libraries to see if it has something suitable.
  6. JeffM
    JeffM Guest
    http://groups.google.com/group/sci....ions+rework+rubberbanding+Xfig+rubber-banding
    "EAGLE" , properly written, is all caps
    (Easily Applicable Graphical Layout Editor).
    Nah. It took me a few minutes
    to make an assortment of generic boxes with X inputs and Y outputs.
    Just slap together something that suits you.
    I also use symbols from existing libraries.
    I forgot to mention in the previous thread
    that EAGLE can export in DXF, making graphics rather portable.
  7. Rich Grise
    Rich Grise Guest
  8. Wayne
    Wayne Guest
    I have tried to find EAGLE. I found EAGLE 4.16 for LINUX and MAC, but
    even though I read it is supposed to be available for WINDOWS I cannot find
    it. Does anyone know where it can be found, are my eyes worse than my
    optometrist say they are, or is there some other strange deed going on?
    Anyone's help will be Greatly Appreciated.
    Thank You,
    Wayne
  9. Check the EAGLE download page at http://www.cadsoft.de/download.htm in
    the program download section. You are looking for
    eagle-win-eng-4.16r1.exe.
  10. Wayne
    Wayne Guest
    You are a Kind Soul Sir. I got it. I got the manual and tutorial as well. I
    will go back shortly and look over the libraries..
    You have been a Champ.
    Thank You,
    Wayne
  11. Geek Chick
    Geek Chick Guest
    Apart from EAGLE, I find myself using ExpressPCB/SCH a lot and it is
    freeware (www.expresspcb.com)
    Cheers,
    Monica
  12. Melodolic
    Melodolic Guest
    I'll try to remember that (but suspect I might not :).
    Aye, you're probably right. I was originally after some prog dedicated to
    the task, but EAGLE is probably as much a prog as such a thing anyway.
    Yup, I started making a library for myself to hold components I couldn't
    find - copied existing ones and modified them.
    I had a look but couldn't see something to do that, and DXF didn't come up
    in the help, either.
  13. Melodolic
    Melodolic Guest
    Thanks - I'll give it a whirl.
  14. JeffM
    JeffM Guest
    Apart from EAGLE,
    As I mentioned in a previous post, EAGLE can export in DXF
    (a nearly universal format).
    It also prints camera-ready artwork.
    Properly categorized, it would be called *promo-ware*.
    (or lock-in-ware or crippleware). Yes, they give it away,
    but it is intended to get you to send the files that it produces to
    them
    so that you will pay them to fabricate your PCBs.
    http://groups.google.com/group/sci....-*-polygons-curves+*-*-*-*-*-camera-ready-art
    It was never intended to be interoperable at any other level.
    Getting it to print requires you to jump thru hoops:
    http://groups.google.com/group/sci....zes+ready-to-be-printed+qq+Postscript-printer
    Trying to import the graphic into another document
    or otherwise use it outside the ExpressPCB app?
    Good luck on that.
    It seems like a terrible candidate for what the OP wants to do.
  15. JeffM
    JeffM Guest
    D'oh. The EXPORT command will give you bitmaps.
    When I created a vector-based file, I downloaded a user-created script.
    Maybe it comes with the main download now.
    http://www.google.com/search?q=DXF.ULP+DXF-data+User-Language-*
  16. Spajky
    Spajky Guest
    better Powerpoint, I used it even for schematics plans on my site :)
