Soft "varnish" on PC boards?
Discussion in 'Electronic Design' started by Ignoramus14946, Jan 20, 2006.
  1. I have a couple of PC boards from where I want to nicely remove
    components. They are covered in soft "varnish", it has a rubbery
    texture. How could Iremove this varnish?
    thanks
    i
  2. PeteS
    PeteS Guest
    That sounds more like one of the varieties of conformal coating. There
    are various removal solvents, but which one you can use depends on the
    coating.
    A pretty universal remover was Freon, and damned fine it as at the task
    too, but that's not really available for outdoor use any more ;)
    [no eco-shouting please, I am merely making an observation]
    You might look in your favourite catalogue and see what is availble
    under 'solvents'
    Cheers
    PeteS
  3. GregS
    GregS Guest
    I have some Acetone, Freon, and some Trichlorethane, but I don't think either
    would remove a rubbery coating, especially silicone.
    I used to have a Trichlorethane fire extinguisher long ago.
    greg
  4. kell
    kell Guest
    Why not just try something harmless like mineral oil. You can go to
    the nasty stuff if that doesn't work.
  5. Al
    Al Guest
    Check out: http://www.dynaloy.com/Products/potting_removers.html
    I've used their stuff for years with great success.
    Al
  6. Ian Stirling
    Ian Stirling Guest
    I assume it's SMD components - and the varnish is over the top?
