Jan Panteltje
What was the chipcode dates on that DAB ?
No more than 2 years old no doubt.
If you had not repaired it than also no doubt it would have ended in
landfill taking with it ,perhaps not lead, but antimony, bismuth, tin,
copper, barium , phthalates etc
Actually, in the long ago past when I had the TV repair shop, I had exactly
the same problem on old tube connectors in PCBs and also on inductiors, and old
Philips K8 connectors, some after 2 years too I think.
With leaded solder.
This is also also an issue of better connections, some that allow some movement,
like WIRES for example...
I mean use flexible wires to connect the hot components to a PCB.
That defeats the idea of PCB perhaps.
But I only wanted to point out that that thermal effect is also present in leaded
solder.
It could be worse in leadfree, but you'd have to test in the same setup.
He *could* have resoldered one with 60/40 and when it comes back in 2 years
see which ones gave way ;-)
workin gas TV repair
